RE: U Can Do 60
Well it looks like I need some weight in the tail, so I'll be changing out the HS-545 with an HS-645MG on the rudder and gluing the rear stab with epoxy leaving the bolts in place with epoxy as well in hopes to add weight to the rear. If this dosen't work I may replace the mini digitals with standard size servos depending on my findings.
Blackie
