RCU Forums - View Single Post - Worn Servo Mounts
Old 05-22-2003 | 01:55 PM
ballgunner 's Avatar
ballgunner
Default Worn Servo Mounts
Another way to repair oversized holes is to put a piece of dowel in the hole and glue with epoxy. Be careful when you drill the new holes as the dowel may be harder than the plywood. You can also drill the hole larger before you insert the dowel.
