RE: u-can-do 60
David, If your centerline is the mark on the left and the angle that you are trying to determine is the mark on the right, and taking into consideration that the image has not been reversed as it traveled thru a black hole or some other anomally in transit to the states, then.............. it appears that the stab is angled in the wrong direction. It appears that it will guide your model to the left, if..... I'm viewing your marks correctly. Joe
