RE: Building a DraganFlyer - need to mix speedcontrollers - HELP
i dont know where to get them in the uk but spectrolutions sells them for about $20 for a set of 4. be warned though, they do not work right at rpms above 1000. they will go into negative pitch and loose most of their lift. if you are trying to maek your own and plan on having a higher gear ratio, you will haveto look at the toddsmodels props. however again that would require international shipping. in all my research i have not found a single place in the uk that has those things.
