RCU Forums - View Single Post - servos help
Thread: servos help
Old 04-23-2004 | 10:36 PM
aeajr's Avatar
aeajr
Default RE: servos help
What radio you get is very much a function of budget. How much are you willing to spend?
You can get radio packages with any size servos you like.
Servo City is excellent this way. They will let you custom package your radio.
The Laser 4 would be good for you as the e-starter calls for a minimum 4 channel radio.
Go to this link - click the customize button.
HS- 50, 55 or 81 servos would be appropriate for that Plane. I would suggest the HS-55s
Laser 4, 4 hs-55s, electron 6 receiver, micro switch and 600 mah receiver battery ( you won't use it for this plane) would be $172
A MUCH BETTER PACKAGE FOR YOU WOULD BE THE FLASH 5X COMPUTER RADIO $181
It is called the glider package, but it will work great for you and you get a computer radio rather than a standard radio. Much better value!
http://www.servocity.com/html/5-ch_f...m_systems.html
3 hs-81s, micro 555 receiver, switch , receiver battery
These would be my suggestions
If you have more $$ we can go further. If you have a lot less to spend, you might look at a GWS dreamstarter package. The radio is pretty simple but it will fly the plane.
