RCU Forums - View Single Post - Shockflyer Acc??????
Old 04-24-2004 | 07:48 AM
  #74
whackinski's Avatar
whackinski
Default RE: Shockflyer Acc??????
It will not hurt the motor, heres how you program it. The Jeti comes to you with the brake on and soft start enabled, first disable the brake. With all power disconnected push the throttle lever to full, switch on the TX the power the ESC( you should have the motor and flight pac connected)
in about 5 seconds you will hear 4 beeps now pull the throttle to the closed position (quickly) you then hear 2 more beeps and the brake is disabled.
Now for the soft start; the Jeti comes with soft start enabled, follow the same procedure as above. Start with everything off, throttle to full open, turn on TX then power the ESC (system) there will be a series of beeps every 5 seconds, immediately after you hear the double beeps(the third set of beeps) quickly move the throttle to the closed position and you have just switched to Hard Start.
You will not damage your motor with hard start, the Brushless is designed to operate in this mode for aerobatic models. The instructions claim a 20% increase in amps and rpms from the same battery pack, I believe it! There was a noticeable difference in power after the change over.
Good luck Now go flying!!!
