RE: Wild Hare Extra arrives
moving the battery and servo to the rear of the canopy achieve these results. NOte the rudder cables are still not installed, and the canopy has not been glue, screwed or however i will put it on..
I always balance mine upside down but i needed to know 1st were the CG was located now that i know were the CG is by the closer portion of the wing i will use the GP balance machine and see how that turns out. i forgot that i wanted to add a pilot so i may have a bogues CG as i just mounted the rudder servo we'll see. i taped on a string on both wings to see were the CG was located for tank and balance purpose...also my things are just sitting in the plane so it would have been hard to keep them in place inverted....
