RCU Forums - View Single Post - Mid range problem UPDATE... SOLVED
Old 04-24-2004 | 05:56 PM
jsn
My Feedback: (8)
Default RE: Mid range problem
My Mid range problem is solved... it must have been the small ding on the Low speed needle. I flew the motor 6 flights today, it dead sticked me one time, my fault I had the Idle set a bit to low. transition is great and now I can play all I want in the mid range throttle setting without it flaming out. just as a good test I spent several min putting around almost every flight at about 1/4 to 3/8 throttle without giving it a burp of full throttle to clear it out... it transitioned right out when I punched it. A week ago before I worked on the low speed needle this flight would have lasted about 20 to 30 SECONDS in low speed /midrange flight before it flamed out on it's own or died as it tried to give it throttle.
Thanks for all the help
John
