RCU Forums - View Single Post - Pull Pull Setup Help Please
Old 04-24-2004 | 09:04 PM
RCLIVIN
My Feedback: (46)
Default RE: Pull Pull Setup Help Please
the pivot point for your cables @ the rudder horn needs to be right on the hinge line, the distance between the two pull pull cables @ the rudder horn needs to be exactly the same as the distance between the two cables @ the servo arm. For example if you have three inches between the cables @ the servo arm you need three inches between the cables @ the rudder horn, regaurdless if you crossed the cables are not.
