RCU Forums - View Single Post - Pull Pull Setup Help Please
Old 04-25-2004 | 07:27 AM
Stick Jammer
Default RE: Pull Pull Setup Help Please
Original: Hooked-On-RC
The servo arm I am using is larger than the control horn on my rudder. Will that cause any issues? Also the servo arm on my rudder servo has some offset built into it, should I scrap that for something else?
A servo arm that is longer than the control horn (measured from the pivot point to the hinge line) will create a mechanical DISadvantage at the servo. This is typically not the best set up as you are lowering the available torque of the servo. Keeping them the same length is the optimum set up for pull-pull. In regards to the offset, you would only need offset in the servo arm if there is any offset at the control horn present (pivot points substantially behind the hinge line). The control horn pivot point should be exactly on the hinge line or very slightly behind it, never in front of it. Set up in this manner, a straight servo arm of the same length as the control horn would be the optimum to achieve the correct geometry.
