RCU Forums - View Single Post - Prop comes loose too often!
Old 04-25-2004 | 12:49 PM
siclick33
Default RE: Prop comes loose too often!
Just put two nuts on. The second one will help to lock the first one in place. I had the same problem with a four stroke but it hasn't happened since using two nuts. You can also buy special locking nuts designed for four strokes (o.s. make some)
