RCU Forums - View Single Post - Wild Hare Extra arrives
Old 04-25-2004 | 01:35 PM
  #50
krayzc-RCU
My Feedback: (31)
Default RE: Wild Hare Extra arrives
at the field but not for long I got N about a 3 minute flight. I needed 4 clicks of left ailerons on trim step 1 (jr 8103) 3 clicks of up elevator. My motor needed an adjustment on the low end this in turn made the motor idle higher than I could adjust from the transmitter, I did not have a short Allen wrench to adjust this afterwards so I headed on back home. I am going to need a -3 or so to start on my rudder to elevator mix, and about a 5 and -5 to start on the rudder to ailerons mix. I did not have any mixes on for the 1st flight. The plane will fly for 5 seconds or so with out elevator inverted then it needed a slight push. It lands very well and I was flying with a cross wind and it comes right on home like it should. That is about all I know at this time I didn't even do an ailerons roll so I am not sure how the rates on that deal. well I am off to school talk at you all later.....
ID:	126141   Click image for larger version
ID:	126142   Click image for larger version
