RCU Forums - View Single Post - Prop comes loose too often!
Old 04-25-2004 | 07:55 PM
Stick Jammer
Default RE: Prop comes loose too often!
Bluebrew,
Sounds like you are simply not tightening the nuts enough. They need to be TIGHT. Use a 6" wrench and don't be afraid to put some pressure on it. Nylon lock nuts won't work for the prop as there is no way to hold the prop shaft to spin the nut down against the washer.
