RCU Forums - View Single Post - Stabilizers on control surfaces
Old 04-25-2004 | 10:10 PM
Forgues Research's Avatar
Forgues Research
My Feedback: (7)
Default RE: Stabilizers on control surfaces
ORIGINAL: dick Hanson
Boost tabs do work - however - where is you info re: How much the tab changes the efficiency of the deflected surface?
For all practical purposes, the amount of area the boost tab takes away from the control surface is neglegible concerning our models.
I have been using boost tabs on all my large ones with great success.
For instance, on my last Extra (33%), I had enough servo power not to need them,but on the other hand, after 3 15 minutes flights of aerobatics, (not 3D) I checked the battery voltage and it was as if I had just taken the battery off the charger., So one can use also smaller battery, smaller servos etc.
Roger
