RCU Forums - View Single Post - Nylon spinner
Old 04-25-2004 | 10:17 PM
zetor
Default RE: Nylon spinner
I have a great planes aluminum 2.5" spinner that will accomodate any prop for a .46 engine. It just looks to me like that there would be plastic spinners out there that could do the same thing. Is there a drawback to having a spinner that doesn't hug the prop? All the engine manuals that I've seen say it is so important to balance a prop. Well if it is so important, then grinding on a spinner and ending up with a balanced spinner looks like it would be very difficult.
ORIGINAL: MinnFlyer
ORIGINAL: zetor
What I don't understand is why doesn't someone step up and make a simple spinner that doesn't need grinding out for the wider props.
Simple... If they made a spinner to fit each brand (and size) of prop, they would have to make about 100 molds for each spinner. and of that hundred or so types, how many do you think your LHS would carry? And in what Color?
The simplest way around this is to make each spinner for the smallest (reasonable) size prop.
If you need it bigger, you can enlarge it, but if it's too big, you can't make it smaller.
