RE: Do modules go bad?
Hi IRL,
Yes, modules do need to be retuned occasionally.
You may send in the module alone if you like, but it is always recommended to send the complete system in for a check up if the system is older.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
