RE: u-can-do 60
Hondalan - several of us have been on this thread from the get-go and developed a fun relationship with one another while also getting into the nuts and bolts of the UCD 60. In the process we all get a bit side tracked at times, but eventually get back on the topic of the original thread. Beyond the joking around and non related questions, there is really good stuff in here, but the fun stuff and even the off track questions helps to keep us going and to get new info posted as we find things out.
Since you asked for some help, I used Hitec 475's on all movable surfaces for mine. Others have beefed up the torque and speed as a personal preference. When you consider the size and that some of us are using less power on the nose ( OS 91 Surpass ) these are working fine. I have roughly 75-100 flights on mine so far and no complaints. Those using more power and wanting more torque and faster servo response have used more expensive and higher grade servos. The 645 is a good example.
