RCU Forums - View Single Post - Saito 150 help!!!!!
Old 06-27-2002 | 01:00 PM
edge_fanatic
Default Just remember...
On a Saito, the low needle affects the ability of the high needle to regulate....Adjust the low end a bit richer than normal, and you'll have plenty of fuel at the high end...
However, having a slightly lean low end will prove to be bad at the high end.
I'd richen up the low end a bit to see if you can get the high end richer.
