RCU Forums - View Single Post - Saito 150 help!!!!!
Old 06-28-2002 | 09:29 PM
lennyk
My Feedback: (12)
Default Saito 150 help!!!!!
My 150's needle is set at 1 1/2 turns.
Are you using a tach to set ?
I find it is best to set the idle a bit rich then peak the high speed and back off a few hundred rpm,
then check and adjust the idle if necessary, then do over the high speed.
