Helpful tips
Don't wear any loose clothing that can be caught by the prop.
Be careful when turning the prop by hand... the engine can accidentally be started.
Be aware of where your arms and hands are. (If it's your first time have someone at the field help you.)
Make sure to pull out when you hear the "pop" from your 2-stroke
I probably forgot a lot of things, but hope this helps!
-Brian
