Originally posted by AQ500
2. Turn the prop by hand clockwise until you can feel compression.
AQ500, thanks for the input. Could you explain the reason for doing step 2 ? Do I need to leave the engine in the compression mode before using the starter ?
Yes, I need to reverse my wiring and check the battery. I am using a 12V 5Ah wet cell and it could be undercharged......
