RCU Forums - View Single Post - How to use starter correctly ?
Old 06-27-2002 | 05:30 AM
C_Watkins's Avatar
C_Watkins
My Feedback: (10)
Default To have some "Slack"
By turning the prop slowly "clockwise" until you just start to feel compression, you
are giving the engine a bit of rotation time before hitting the compression stroke
while spinning it with the starter the right way(counterclockwise).
Lots of the starters won't do much if you already have the engine on compression
in the starting direction. Particularly if they have long leads and a weak battery.
