RE: gp pt-19 and os 91 fx muffler problem
that looks like a good muffler but the way the cowl is,if the engine is mounted inverted you would only have to cut out the inserts in front of the cowl for cooling and just a little for the muffler. the cowl is so narrow up front and the distance required from the firewall puts the engine way up front i will look into also keep me posted on your findings and i will do the same take care mike
