LI-POLY POWER - I THINK I FIGURED IT OUT!!
This is my question – will this work????
Aircraft: TopFlite P40 Warhawk (10 – 11Lbs.)
Motor: AXi 4130-16 with Master Airscrew wooden elect prop 14x10. This should operate at @8000rpm pulling 49 amps working out to be 975 watts.
Jeti 77 opto controller NO BEC
Kokam Li-poly setup as follows:
(please click on link for diagram)
OK – is this correct or is this overkill? Is this a 8s2p set-up? Can you charge these all at once (Triton Charger); if so, what do you enter for number of cells when using Triton charger? OR . . . . is this completely wrong???? Any info would be greatly appreciated; I always try to read MANY threads before asking probably dumb questions.
