RCU Forums - View Single Post - Engine Mounting question
Old 04-27-2004 | 06:50 PM
phread59
Default RE: Engine Mounting question
Connery I forgot to mention. The plan calls for 2 down and 2 to the right (Degrees thrust). This plan is from RCM. The trainer series is based off this plan. I wanted a kit for years couldn't find one until this plan came out. So I am scratching one up from the plans. It is the same as the kit except they added a bolt on wing. I can't wait to get it in the air. Right now I am fighting with the cheeks. They interfere with the motor mount. I am afraid they will have to go. Good luck with your plane. A freind of mine had one many years ago. Seeing his fly made me want one.
Mark Shuman
PS: check the plan you will see the built in down the fuse side doublers have it built in.
