RCU Forums - View Single Post - Ball bearings vs Roller
Old 04-27-2004 | 07:46 PM
av8tor1977's Avatar
av8tor1977
Default RE: Ball bearings vs Roller
Could you post a pic? I once had a 21cc engine that really didn't look like the other Echo/Kioritz engines, but it was and I decided it wasn't worth converting. I eventually used the cylinder & piston as a "big bore kit" for my Kioritz 16cc. (Don't go there either, as it worked out well but was a very involved project.)
Anyway, the one I had, had a small lightweight crankcase that looked attractive, (light), but it only had one bearing in the crankcase and the other crank bearing was mounted with bend over tabs in a piece of aluminum that was part of the weedeater mechanism and overall metal that I needed to cut off. I could have machined the crankcase for another bearing, but it just wasn't worth it for a 21cc engine.
Good luck,
AV8TOR
