Was tested with OS91FX...CG is no problem.
Will be tail heavy with servos in rear. Also..its bad to move mass away from the center of a plane. This makes tumbling maneuvers and snaps harder to stop precisely. Use stock servo locations with pull-pull linkages on the rudder and elevators.
The prototype was 7.5lbs.
ORIGINAL: Dominique ACM
I just buy an Epsilon but must wait 1 month to have it. It is possible to have answers to the following questions ?
What about the CG with the OS91Fx ?
It is possible to place the servos (stab) at the rear ?
What about the weight ?
Thanks for the answers.
Dominique
