RCU Forums - View Single Post - Battery voltages
Old 04-28-2004 | 04:49 AM
Gryphon
Default RE: Battery voltages
Don't any of you fully drain the battery before charging it?
I thought that not fully draining it before charging will eventually lead to memory issue with the battery, meaning that it will hold less charge (mah).
I use my computerized charger to fully drain the battery before charging it.
Ideally for the Rx and Tx I use a low discharge setting, then for charging I use the slow wall charger over night.
What are your views on this? Should I do the discharge every once in a while?
