Yes it can be removed ....The only thing you will need to do is pick up shorter screw to bolt it back together....Looking at you pic's ....removing the spacer will give you all the room you will need....JW
ORIGINAL: armyrcer-RCU
JW from what i understand the spacer cannot be removed.
