RCU Forums - View Single Post - diff c cup for fun factor truck
Old 04-29-2004 | 05:05 PM
Sweetshoes90210's Avatar
Sweetshoes90210
Default RE: diff c cup for fun factor truck
There is a way that you can set up your cups so that they will never break * guarenteed *
first of all this cant fix diff cups, only prevent them from ever breaking again so you need to start with 4 good diff cups.
buy a piece of 7/16 diameter brass tubing
cut off 4 pieces that are 1/4 inches long.
get some aluminum foil, tin foil or some thing that is similar to that.
cut 4 strips that are 1/4 inch wide and about 6 inches long.
wrap one strip around a diff cup and take one of the pieces of brass tubing and try to fit it on.
it probably wont fit so remove one turn of the foil and try again.
repeat this until the brass piece fits over the foil.
incase you are wondering, you need the foil because the diff cup is a little smaller than the brass tubing on the inside and the foil takes up that little bit of space.
after the brass piece fits over the diff cup and foil and is not loose, put a couple drops of thin CA glue (tire glue, superglue) on it and let it sit for about 5 minutes while the glue dries completely.
repeat for the other three diff cups.
the last thing that you need to do is file down the little part of the shock tower that is near the diff cup. this is nessasary because the now slightly larger diff cup needs a little more room.
Once you do this, you cups should be bullet proof..., it worked for me, I have never once broke a cup because of this idea.
Good luck (Credit to - nitromacguyver)
