9CAP Flaperon function
How is it that whenever I activate the Flaperon function and then go to set the percentage of flap movement that the Aileron centering gets changed? I have tried this on several planes and always get the same result. Am I missing something? I referred to the manual and the website with no better results. I don't have this problem on my other radios of a different mfr. I would think that after you have set-up the Ailerons (throws and centering) that when Flaperons are activated that your centering and set-up should not change. So to correct this, I have to redo the Ailerons and constantly go back and forth between the functions until it is good. Any input/advice would be appreciated!
