RE: Screw Kits??
Yea, you just screw the fine threaded ones into the plastic the same way you do the course, self tapping ones. They hold better due to the more threads-per-inch.
You dont need self tapping, the fine threaded ones work excellent... Plus if you have a hole that was previously used by a self tapping one, the fine threaded screw will easily hold in that hole.
