RE: Frustrated Triton Owner
For all of you using it in NiMh mode, bear in mind that the DEFAULT MAX CHARGE INPUT is set to 1000mAh - that is why the Triton is terminating the charge when it has put 1Ah into a pack that has a larger capacity than that. (pg 14 of the manual). Solution to the 'problem' is also found on that page. No problems with my Triton so far, been charging everything from 1 cell to 20 cell, 150mAh to 3300mAh NiCad and NiMh, also LiPo and Pb. One thing as noted is to use good charge leads.
