RCU Forums - View Single Post - Does your DA50 do this?
Old 04-30-2004 | 10:14 AM
  #117
MustangFan
Default RE: Does your DA50 do this?
BHunn3
Does your engine exhibit the problems noted ??
DA set my needles at low 1 1/4 high 1 5/8 .... didn't work.
I'm guessing if I do as I did last year my needles will be low 1.0 or less .... high 2.0+. Almost 4 gallons of gas used.
After I adjusted the low needle very lean ( would quit if opened very quickly ... eliminated by using throttle delay ) the engine idled better and quit LESS.
I also set up high/low idle's to help with flying vs landing ( it quit on landing).
