RE: Roll coupling?
Well.... I thought about that doug but.... Since the plane tends to tuck towards the top I will be mixing down elevator which means if it is on all the time, if I need rudder application in level flight the plane will dive?? IE: on landing, I use rudder to correct it will add down elevator at the same time. Correct me if I am wrong but.... isn't this a bad thing?
