RCU Forums - View Single Post - Roll coupling?
Old 04-30-2004 | 11:32 PM
Tim Redelman's Avatar
Tim Redelman
My Feedback: (36)
Default RE: Roll coupling?
all you have to do is activate the mix with the gear switch and make your adjustments when the gear is up. Then when you land the mix will be off and all is good in the world.
You can also use the flap switch, I.E. flaps up mix on, flaps anywhere else mix off.
Tim
