RE: Motor mount angle
You say you are "rebuilding" a C-17E. What was the extent of damage ? If the fuse was damaged, was it repaired so that it is straight ? That amount of downthrust "seems" quite extensive. I would check the specs for that plane and see what is called for for down and/or right thrust.
