RE: U Can Do 60
Herc, now this is just me and how I approach every model. Recommended control throws and recommended CG. You could add weight up front to start and remove small portions to suit your comfort level as you work your way back on the CG. Everything else sounds to be in order. Good luck, those five months will be worth it once you fly it. Joe
