RCU Forums - View Single Post - magnum engine que.
Old 05-01-2004 | 11:50 AM
Rodney
Default RE: magnum engine que.
All 4 strokes need to have the valves adjusted periodically. First time, right out of box, make sure factory setting is correct. second time, immediately after a couple of tanks of fuel, initial wear will take the high points of the pushrods and cam and cause need for some adjustment. After that, after every couple of hours of run time check things out. True for all brands, no particular brand is more immune to wear than the others.
