RE: U Can Do 60
Andy I with Joe with the CG per plans Keep the cowl off for the first two runs so you can do a good wrench check out for any loose bolts and will make any engine adjustments. I still run mine with it off . Landing gear is known for coming loose as well I had mine fall off on one side Made it fun landing it into the tall grass no damage . It will float on in so have fun.
