RE: U Can Do 60
Steve, on the cowl thing, I maidened this one with the cowl off. I never had it off with the other UCDs I've had. Pain in the butt when making adjustments. Heres the Q. Do you feel that the ramp under the fuse makes it pitch up on the nose. I couldn't figure it out at first, but that is the conclusion I came up with. When flying level it pitched up like it was way tail heavy and when inverted it responded like it was severely nose heavy. Seemed to me that the ramp acted like an airfoil.
Also the cowl on this one is heavier than past ones. 3.2 oz. so, Andy you better compensate for that or you will be re-balancing when you put it on later. Joe
