RE: Prop size
the first number is the diameter. the second number is the pitch. pitch is the distance forward that the prop will go in one revolution. so a 10x6 prop is 10 inches in diameter and it will cause the plane to go forward 6 inches every time it turns once. A 10x7 prop has more "twist" in the blades, so it will cause the pane to go forward 7 inches every time around.
