RCU Forums - View Single Post - coyote wing replacement
Old 06-05-2003 | 10:56 AM
Toro1's Avatar
Toro1
Default coyote wing replacement
If you still have the wing you can have cores cut to that same wing plan form. I use a company out here in California called WWW.flyingfoam.com Check it out they may be able to help you out. All you will have to do is send them the old wing and they can cut it exactly to the other. If you change the airfoil you may not fit the wing to the fuselage perfectly.
JB
