RCU Forums - View Single Post - AV8R framed up
Old 05-02-2004 | 08:58 AM
Don Perry's Avatar
Don Perry
My Feedback: (51)
Default RE: AV8R framed up
Shok
Here is some vid taken from mine http://www.rnlinc.com/rc/AV8R.wmv
www.rnlinc.com
Just make sure it is on the nose heavy side.
As mine was way tail heavy when I got it. It flew ok but at the top of a loop it would go inverted flat. I just got very Lucky I got it out in time.
Once cg moved to correct position the jet fly just fine, and if you attempt a loop too slow it will do a cool tail slide at the top where it runs out of speed, then the nose flops down and it flys right out!
My FTE has run flawlessly every time and has almost unlimited vertical.
Let me know if you have any questions.
