RE: MultiPlex Royal Evo 12 tx ?
"I like the 12 channels, but it forces you to use TWO ailerons ch and TWO flp ch which took 4 ch total."
Ehab
Is this normal? Couldn't you use a Y-harness for the ailerons and one for the Flaps setting the servos in reverse positions in the wings like I do with my JR radio if I don't want to tie up other channels?
After reading the specs. on the web site. It seems the radio can be used with any rx? Does this radio work like the Hitec eclipse tx that can be set to any channel matching the rx? Or does this only work went you're using the Royal Evo rx?
Thanks for all the help..
Steven T.
