RCU Forums - View Single Post - u-can-do 60
Thread: u-can-do 60
Old 05-02-2004 | 01:39 PM
  #547
autoguns's Avatar
autoguns
Default RE: u-can-do 60
LL I used some small fuel tubbing ,to make some rubber washers ..I then put a #2 flat washer on the screw, then the rubber washers I made from the small fuel tubbing ...I then put a drop of thin CA in the hole....I ran the screw in while the CA was setting up....NOTE I did run the screw in and out to make the threads ....CA let harden as Father Joe said ....Then do the above.....it worked well for me.....JW
ORIGINAL: lord lucan
did anyone have a bit of trouble with the cowl on the UCD.?.....ran her up again yesterday ..the cowl seems to be vibrating quite a lot ....couple of the screws came loose..yeah the were in well tight ...its starting to chaff on the back of the spinner.[:-]..2mm gap there... it is a bit lightweight...? any ideas..all is balanced spot on....catch ya later
