RE: MultiPlex Royal Evo 12 tx ?
I have my 12 ch Royal Evo now with synthesizer and it is great. I have not had much time to fly lately (work), so I have little experience with it yet. As for using it with any receiver, not yet. It will soon be able to be used with any PPM receiver as soon as the shift select portion of the software is activated. That should happen in two or three months. As for now, you can only use with PPM RXs that are the same shift as JR. But for a high dollar jet, I would only use the MPX IPD receivers anyway. I have used them for three years now and they have been rock solid.
Ehab, why do you say !QUOT!it forces you to use TWO ailerons ch and TWO flp ch which took 4 ch total!QUOT!??? If you want, you should be able to use a Y on those channels. But I usually hook them direct and use separate channels so I can program crow if you want.
