RCU Forums - View Single Post - How have others hooked up water rudder?
Old 05-02-2004 | 06:51 PM
iflyj3's Avatar
iflyj3
My Feedback: (7)
Default RE: How have others hooked up water rudder?
ORIGINAL: canadagoose
I added a water rudder to both floats with a rod connecting the two and fishing line still goes to the rudder on either side with a spring. I'll give this a try, I think the line going to the rear gear legs and pulleys as Jim suggested would be better but i have nothing to use as pulleys right now. It should steer good on the water now anyways.
I can see that the way i have it now the line might get snagged on things.
Unless you have a lot of power, that rod connecting the two rudders will dig in when you rotate to take off. I had this on one plane and had to remove it.
