RE: aileron differential
Doesn't take much to put in differential. Why not try it without first, then put it in, then you can see the difference for yourself. If it's a flatbottom wing about twice as much up as down would be a good place to start. The old Ercoupe had 10 degrees down and 30 up if I remember correctly. A mediocre plane can be made to do decent axial rolls with differential
