RCU Forums - View Single Post - Mounting servos
Old 05-03-2004 | 02:24 PM
cstevenpeterson
My Feedback: (21)
Default RE: Mounting servos
Top and bottom - don't forget to use the metal grommets that also come with the servo. They install from the bottom through the rubber pieces. When you tighten the screws, only tighten a slight bit past the point where the screw just makes contact with the rubber - you want to make sure that the rubber pieces do their job and that is shock/vibration isolation.
Steve
